Engine mounts?
https://mail.slantsix.org/forum/viewtopic.php?t=4797
Author:  Jopapa [ Sun Jan 12, 2003 10:23 pm ]
Post subject:  Engine mounts?
While I was working on the Dart today, I noticed that the engine mounts are completely FUBAR.
Where can I get polyurethane engine mounts and a poly tranny mount for a 225 w/ an A904? And how can I support the engine while I'm changing the mounts? I see no way to hold the thing up :?
Author:  Patrick Devlin [ Mon Jan 13, 2003 7:41 am ]
I don't know where to get poly mounts, but rubber mounts can be found easily in autoparts stores. Are your mounts the biscuit type or the later spool type?
When I changed my mounts (biscuit type) over the summer, I supported the motor under the oil pan with a very large block of wood and a floor jack. I simply unbolted the old mounts, jacked the engine up, slid the new mounts in and let it down.
Author:  Jopapa [ Mon Jan 20, 2003 4:09 pm ]
They're biscuit, I think. It's a 1970.
Author:  Super6 [ Mon Jan 20, 2003 6:11 pm ]
I use the same block of wood on the oil pan method. (Never changed the mounts, but i had to pull the passenger side mount to remove my oil pump) Just have a helper to tell you when to stop jacking.
-Aaron
Author:  Justin [ Mon Jan 20, 2003 6:15 pm ]
Hey,
I've done the same trick with the block of wood and jack under the oil pan only i've used it to take the transmission out...
Justin
