| Solid U-Joints https://mail.slantsix.org/forum/viewtopic.php?t=51744 |
Page 1 of 2 |
| Author: | Rick Covalt [ Wed Apr 17, 2013 2:34 pm ] |
| Post subject: | Solid U-Joints |
Are solid u-joints available in the small 7260 size? Also a conversion joint 7260 X 7290? When I put my 4.56 gears in I will need the conversion joint for the rear. Rick |
| Author: | Old6rodder [ Wed Apr 17, 2013 2:38 pm ] |
I turned my own cups for my 8" adaption, that covered both the size and the spread differences. Nearly any small lathe'll do the job. |
| Author: | Dart270 [ Thu Apr 18, 2013 10:53 am ] |
Both solid 7260 joint and 7260-7290 adapter joint exist. Call a local driveshaft shop, or good indep parts store, or call dennysdriveshaft.com. Lou |
| Author: | Rick Covalt [ Thu Apr 18, 2013 12:30 pm ] |
I looked at Denny's and they do not list the solid one in conversion or 7260. Maybe I'll just call them. |
| Author: | Will [ Thu Apr 18, 2013 12:48 pm ] |
I get the adapter U joint at NAPA. Will |
| Author: | Rick Covalt [ Thu Apr 18, 2013 2:19 pm ] |
I got the adapter joint,but I was looking for the solid version. The joints with grease fittings will be fine with my automatic, but when I go to the 4 speed with slicks I was thinking it would add an extra measure of strength. Rick Just got a note from Denny's and they do not carry the solid ones I need. |
| Author: | slantzilla [ Thu Apr 18, 2013 4:24 pm ] |
If you break a u-joint there is usually another issue. I had regular 7260's in my Valiant and never even wore one out. |
| Author: | Rick Covalt [ Thu Apr 18, 2013 5:03 pm ] |
Ok, that is good to know. I was just guessing that the shock loads from the 4 speed launch would be a lot harder on everything than even a high stall automatic. Covalt |
| Author: | slantzilla [ Thu Apr 18, 2013 8:13 pm ] |
I had a trans brake and 150 shot of giggle gas. Your puny stick is irrelevant. |
| Author: | DusterIdiot [ Thu Apr 18, 2013 8:30 pm ] |
| Post subject: | Lol |
Slant Six: Next Generation? "Your stick is irrelevant. Your launch is irrelevant. Your Valiant will be assimilated and EFI'd...even in wide band, resistance is futile." Locutus of Borg-Warner -D.Idiot |
| Author: | Dart270 [ Fri Apr 19, 2013 2:50 am ] |
I think you meant "Borg-Zilla"... Awesome. I agree you should not be taxing a good stock type 7260 joint. DI could probably break them, though... Lou |
| Author: | sandy in BC [ Fri Apr 19, 2013 6:36 am ] |
stock U joint .....drive shaft loop.....Kevlar Panties. Good to Go |
| Author: | Exner Geek [ Fri Apr 19, 2013 7:14 am ] |
I think solid body u joints are something everybody talks about and nobody has. |
| Author: | slantzilla [ Fri Apr 19, 2013 11:31 am ] |
Solid u-joints are definitely not a good street piece either. |
| Author: | DusterIdiot [ Fri Apr 19, 2013 12:13 pm ] |
| Post subject: | Lol... |
Quote: DI could probably break them, though... Razz ShockedI figure if I solved the clutch problem, the u-joints are next to go, if I don't turn the driveline into a pretzel... |
| Page 1 of 2 | All times are UTC-08:00 |
