It is currently Tue Nov 18, 2025 11:47 am
 Post subject: Solid U-Joints
PostPosted: Wed Apr 17, 2013 2:34 pm
Are solid u-joints available in the small 7260 size?
Also a conversion joint 7260 X 7290?
When I put my 4.56 gears in I will need the conversion joint for the rear.
Rick
PostPosted: Wed Apr 17, 2013 2:38 pm
Car Model: Toad Wagon
I turned my own cups for my 8" adaption, that covered both the size and the spread differences.
Nearly any small lathe'll do the job.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Thu Apr 18, 2013 10:53 am
Both solid 7260 joint and 7260-7290 adapter joint exist. Call a local driveshaft shop, or good indep parts store, or call dennysdriveshaft.com.
PostPosted: Thu Apr 18, 2013 12:30 pm
I looked at Denny's and they do not list the solid one in conversion or 7260. Maybe I'll just call them.
PostPosted: Thu Apr 18, 2013 12:48 pm
I get the adapter U joint at NAPA.
Will
PostPosted: Thu Apr 18, 2013 2:19 pm
I got the adapter joint,but I was looking for the solid version. The joints with grease fittings will be fine with my automatic, but when I go to the 4 speed with slicks I was thinking it would add an extra measure of strength.
Rick
Just got a note from Denny's and they do not carry the solid ones I need.
PostPosted: Thu Apr 18, 2013 4:24 pm
If you break a u-joint there is usually another issue. I had regular 7260's in my Valiant and never even wore one out.
PostPosted: Thu Apr 18, 2013 5:03 pm
Ok, that is good to know. I was just guessing that the shock loads from the 4 speed launch would be a lot harder on everything than even a high stall automatic.
Covalt
PostPosted: Thu Apr 18, 2013 8:13 pm
I had a trans brake and 150 shot of giggle gas. Your puny stick is irrelevant. :lol:
 Post subject: Lol
PostPosted: Thu Apr 18, 2013 8:30 pm
Slant Six: Next Generation?
"Your stick is irrelevant. Your launch is irrelevant. Your Valiant will be assimilated and EFI'd...even in wide band, resistance is futile." Locutus of Borg-Warner
:roll:
PostPosted: Fri Apr 19, 2013 2:50 am
I think you meant "Borg-Zilla"... Awesome.
I agree you should not be taxing a good stock type 7260 joint. DI could probably break them, though... :P :shock:
PostPosted: Fri Apr 19, 2013 6:36 am
stock U joint .....drive shaft loop.....Kevlar Panties.
Good to Go
PostPosted: Fri Apr 19, 2013 7:14 am
I think solid body u joints are something everybody talks about and nobody has.
PostPosted: Fri Apr 19, 2013 11:31 am
Solid u-joints are definitely not a good street piece either.
 Post subject: Lol...
PostPosted: Fri Apr 19, 2013 12:13 pm
Razz Shocked
I figure if I solved the clutch problem, the u-joints are next to go, if I don't turn the driveline into a pretzel...
:lol:
Users browsing this forum: No registered users and 27 guests
