| Drag/centerlink oil pan clearance? https://mail.slantsix.org/forum/viewtopic.php?t=63382 |
| Author: | drgonzo [ Mon Mar 11, 2019 7:21 am ] |
| Post subject: | Drag/centerlink oil pan clearance? |
Would changing to a 273 style center link give enough clearance to run a later model A body slant 6 oil pan in a '63 Dart? |
| Author: | Rick Covalt [ Mon Mar 11, 2019 9:34 am ] |
| Post subject: | Re: Drag/centerlink oil pan clearance? |
I think the bigger problem is the front corner hits the K frame. The center link helps the rear of the pan for sure. I cut and rewelded my K Frame and now I can run most any pan I want. |
| Author: | drgonzo [ Mon Mar 11, 2019 12:11 pm ] |
Quote: I think the bigger problem is the front corner hits the K frame. The center link helps the rear of the pan for sure. I cut and rewelded my K Frame and now I can run most any pan I want.
You know I saw that modified K-frame you did with the tubing. I had forgotten about that. That will probably be my best solution. I have ONE early pan but I'd like to have other options or find another early pan.
| Author: | Exner Geek [ Tue Mar 12, 2019 4:58 am ] |
I think that a dropped drag link will allow you to use a pan from a full size early car in an early A Body. Maybe Doug knows the details. |
| Author: | kesteb [ Tue Mar 12, 2019 9:37 pm ] |
Using the v8 center link allows you to use a Fbody oil pan. But you need to trim the front left corner to clear the k-member. I cut it back a 1/2" and weld a plate over the hole. Other pans may reguire a similar notification. |
| Author: | drgonzo [ Wed Mar 13, 2019 6:10 am ] |
Thanks guys. |
