It is currently Wed Nov 19, 2025 10:36 pm
PostPosted: Thu Jan 30, 2003 7:52 pm
Can anyone help me find these specs? All of these are for a stock 225 slant six.
Valve to piston clearance
Piston to cylinder clearance
wristpin to piston clearance
rod to wristpin clearance
rod to crankshaft clearance
crank to mains w/ bearing clearance
piston TDC to deck clearance
Thanks
PostPosted: Thu Jan 30, 2003 10:06 pm
OK, I will give this a shot....
The actual parts you use will have some effect on these numbers so as they say, " Your results (clearances) may vary"
See Below:
Valve to piston clearance @ .08
Piston to cylinder clearance : Cast pistons @ .0015, Forged @.0035 (street)
wristpin to piston clearance @.001
rod to wristpin clearance = Press Fit
rod to crankshaft clearance @ .001 to .0015
crank to mains w/ bearing clearance @ .002 to .003
piston TDC to deck clearance = Where ever it ends-up, (unless it's a quanch set-up) stock is about -.140 to -.165
PostPosted: Fri Jan 31, 2003 12:37 am
wow that's perfect, thanks a lot Doc
PostPosted: Fri Jan 31, 2003 6:57 am
Just to add a bit more...
The valve-piston clearance on a stock motor is something like 0.4", but gets less as you put in bigger cams, mill the head, or go to a shorter deck height (pistons higher up or deck mill).
I measured this clearance on my Slant with stock bottom end, but 0.090" milled head and MP 0.490" cam and still got over 0.250" clearance.
The 0.080" clearance that Doug gave is a minimum clearance, and you should measure yours (play-dough on top of piston and turn motor over slowly with all assembled).
PostPosted: Fri Jan 31, 2003 2:24 pm
PLAY-DOH?!?! :shock: now thats something i didnt know :)
