It is currently Thu Nov 20, 2025 2:28 am
 Post subject: Smoking regulators
PostPosted: Sat Feb 08, 2003 9:58 am
I "smoked" my second voltage regulator. When I turn on the ignition my regulator fries. This is the second one that I destroyed. I have checked the manuals and cannot find the reason. i think it has something to do with the resistance or wiring.
Does anyone know where to start.
Bob Brady
Slanted 67 Barracuda
PostPosted: Sat Feb 08, 2003 11:26 am
the only voltage to it should be the wire from the ballast resistor thats spliced into the "I" wire of reg.........i'd have to guess either 1 of the 2 field wires is shorted or a problem internally with the alternator.
PostPosted: Sun Feb 09, 2003 12:37 pm
:o It is fixed. The only thing I did was swap connections at the ballast resistor and it stopped frying requlators.
Guess that was the cause.
Bob Brady
 Post subject: Regulator shmegulator
PostPosted: Sun Feb 09, 2003 7:17 pm
Try a one wire style alternator... you pull the plug on the original regulator, run a single wire from the alternator to the battery, and voila no worries. Been running a powermaster 200A one wire with no issues.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 5 guests
