It is currently Tue Nov 18, 2025 3:12 pm
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Fri May 24, 2013 2:19 pm
It's Phil's Automotive in Waynesboro, Pa. (Actually Quincy,Pa) I will get you a phone number. I called and asked what a .120 cut would be and he said that it would be about the same as mine, $80
Rick
Phone number -717-749-7201
PostPosted: Fri May 24, 2013 6:27 pm
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
Honestly, $150 isn't too bad for a .125" mill. That's a lot of passes with the cutter. :D
That's true..
I talked to a guy about having a cut of 110 done today. He said it is time consuming because it only takes off about 4 thousandths a pass.
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Fri May 24, 2013 8:17 pm
When I had my head milled I also had it totally rebuilt with some special kind of new valve stem seal. Total cost was something like $500. The new valve stem seals required machining, too.
PostPosted: Sat May 25, 2013 5:00 am
I started out with a head that was already .025. Then had another .100 removed (cost $65.00). Chambers wound up at 39 cc's.
I think Lou had one head "angled" milled .100 on one side and .200 on the other side, but he will have to confirm.
 Post subject: Positive seals?
PostPosted: Sat May 25, 2013 8:12 am
Hopefully they weren't positive seals, those work OK for racing but aren't recommended for street use.
PostPosted: Sat May 25, 2013 8:20 am
I know Putzie did an angle mill too.
PostPosted: Sat May 25, 2013 8:00 pm
does anyone know how far you can go before on an angle mill before the bolt holes wont line up properly?
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
 Post subject: Lou...
PostPosted: Sat May 25, 2013 9:19 pm
I think if you look up angle mill Lou had done this and the milling mentioned was about the limit the bolts would allow.
PostPosted: Sun May 26, 2013 12:47 am
Wouldn't you have to spot mill the bolt holes so there isn't an angle under the bolt head?
 Post subject: Only...
PostPosted: Sun May 26, 2013 8:34 am
If the angle is slight enough there is enough tolerance in the holes to be off a little...I suspect that anything out an 1/8" or more would need extra attention. Spotfacing would be needed for proper clamping force, but we'll have to wait for Lou to catch up to the thread and see what he did.
PostPosted: Sun May 26, 2013 8:59 am
I think hardened washers would allow this to work. The mismatch would be shared by the bolt head and the washer....cutting the variation in half and making it negligible.
I agree anything over .125 would require additional attention.
.....things dont always have to be "right" to work.
PostPosted: Sun May 26, 2013 9:31 am
I have done a 0.080"/0.180" cut (manifold/plug sides), and up to 0.110"/0.210" on one head. No bolt or washer funny business of any kind. The angles are very slight. One was a 68-74 head and one was a 64 head. These have been on and off motors many times with no problems. Head chamber ranges from 30-40 cc's depending on which mill and which valves/seats you use. Don't make anything more complicated than it needs to be is my motto.
PostPosted: Sun May 26, 2013 10:52 am
Called a local machine shop and he said no more than $100 for a 110 cut.
PostPosted: Sun May 26, 2013 5:52 pm
I paid $100 bucks to have .1 whacked off before.
Kev
PostPosted: Sun May 26, 2013 7:28 pm
That is a fair price.
Users browsing this forum: No registered users and 15 guests
