It is currently Mon Nov 17, 2025 7:17 pm
Post new topic  Reply to topic  [ 71 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Sat Nov 10, 2018 9:19 am
Yep, this gives me almost 6 months to put the front suspension back on and drop in the engine/trans.
Jeeze, I better get crankin' on this thing. Time is awastin'.
PostPosted: Mon Mar 30, 2020 4:05 pm
Well, it only took a pandemic to finally get me some shop time. It's been well over a year since I have been able to update this. Lots of family dramas have come and gone, I am going to make some progress while things are relatively quiet.
So, I finally have the car on 4 wheels.....
Well, sort of...
I managed to get the car INSIDE the shop (finally)...
AND....the Lexan windows and fancy new interior is in the car...
Again, well sort of....
But hey, it is progress WHOO-HOO!!!!!
PostPosted: Mon Mar 30, 2020 4:31 pm
Glad to see this.Thar B body is is an interesting project. Maybe when this pandemic is all over we will have another racer ready to go!
PostPosted: Mon Mar 30, 2020 5:12 pm
Yep, would love to see you and this car at a track, Matt! I'm thinking July...
PostPosted: Mon Mar 30, 2020 5:41 pm
I don't think those are the four wheels that you really want but Pandemic progress is progress... Get to it.
Commit and geterdone.
PostPosted: Sun Apr 05, 2020 6:20 am
I pulled the front fenders off and stripped all the remaining items from the engine compartment in prep for paint. The engine compartment is in much better shape than I thought. Just needs primer and paint.
It seems that AMD has discontinued floor pans for the 65 Belvedere so I bought one of the last ones they had. The current floor is a bunch of metal patches (some very poorly installed). I figured I may as well install it now and be done with it. I cut the old floor out, just need to trim up the edges and set the new floor into place. Maybe now, the carpet will finally lay flat.
PostPosted: Sun Apr 05, 2020 8:41 am
Keep at it Matt!! :D :D
PostPosted: Mon Apr 06, 2020 9:52 am
I like it without floors.
Time to fab up some tube frame connectors, supports and then put in an aluminum floor.. fast n' light!
PostPosted: Mon Apr 06, 2020 1:54 pm
I would have considered an aluminum floor but I already have the AMD floor. I will be adding frame connectors. I haven't decided on tube or square stock for those, I have both on hand.
PostPosted: Mon Apr 06, 2020 2:48 pm
Sell that AMD piece at a markup since they aren't made any more! It's a racecar.
:D :D
PostPosted: Mon May 11, 2020 5:51 am
I have the front floor pan test fitted and just about ready to weld in. I can't seem to get the holes to align for the seat brackets and the outside seat belt mounts. I may just have to get them as close as possible and redrill if needed. I need to level the chassis on the jack stands before I start welding. I noticed that the passenger side isn't sitting completely on the jack stand. This is due to the right side leaf spring being stiffer than the left. I just need to drop the axle off the stands so the chassis is resting firmly on the jack stands.
